Topic di riferimento per la monoposto McLaren MP4-28
SCHEDA TECNICA:
Chassis
Monocoque    McLaren-moulded carbonfibre composite incorporating front and side impact structures, and survival cell
Front suspension    Inboard torsion bar/damper system operated by pullrod and bell crank with a double wishbone arrangement
Rear suspension    Inboard torsion bar/damper system operated by pullrod and bell crank with a double wishbone arrangement
Electronics    McLaren Electronic Systems. Including chassis control, engine control, data acquisition, dashboard, alternator, sensors, data analysis and telemetry.
Bodywork    Carbon-fibre composite. Including engine cover, sidepods, floor, nose, front wing and rear wing. Driver-operated drag reduction system
Lubricants & Fluids    Mobilith SHC™ 1500 Grease – lubricates the four tripod joints on the drive-shafts resisting the high temperatures generated by the exhaust and braking systems
Mobilith SHC™ 220 Grease – minimises rolling resistance in the car's ceramic wheel bearings to help maximise speed.
Mobil SHC™ Hydraulic Oil – running at over 200 bar and 100° C this fluid is an essential part of the hydraulic system which controls gear shift, the throttles and operation of DRS and steering systems
Tyres    Pirelli P Zero
Radio    Kenwood
Race wheels    Enkei
Brake calipers    Akebono
Master cylinders    Akebono
Batteries    GS Yuasa Corporation
Steering    McLaren power-assisted
Instruments    McLaren Electronic Systems
Paint solutions    AkzoNobel Car Refinishes using Sikkens products
Engine
Type    Mercedes-Benz FO 108F
Capacity    2.4 litres
Cylinders    8
Maximum rpm    18,000
Bank angle    90°
Piston bore maximum    98mm
Number of valves    32
Fuel    ExxonMobil High Performance Unleaded (5.75% bio fuel)
Spark plugs    NGK Formula 1 specification racing spark plugs
Lubricants    Mobil 1™ Engine Oil – for long engine life, protection and cooling combined with improved fuel economy
Weight    95kg (minimum FIA regulation weight)
KERS Hybrid
Type    Mercedes-Benz
e-Motor    Engine-mounted electrical motor/generator
ESS    Integrated energy storage cells and power electronics
Power    60 kW
Transmission
Gearbox    McLaren-moulded carbon-fibre composite
Integral rear impact structure
Gears    Seven forward and one reverse
Gear selection    McLaren seamless shift, hand-operated
Clutch    Carbon/carbon, hand-operated
Lubricants    Mobil 1 SHC™ Gear Oil –  provides reduced fluid traction losses improving gearbox efficiency and delivering more power to the rear wheels
fonte: mclaren.com
Data evento: 31 gennaio 2013
Presentazione della MP4-28
Il prossimo giovedì 31 gennaio il Team Vodafone McLaren Mercedes svelerà la MP4-28, la nostra nuova vettura per la stagione 2013 di F1. Noi condivideremo l'evento LIVE con i nostri fans!
La presentazione della vettura sarà trasmessa in esclusiva LIVE direttamente dal MTC a partire dalle ore 10:30 (11:30 ora italiana) - e sarà disponibile sul sito McLaren.com ed attraverso i maggiori social network: il canale ufficiale di YouTube e le pagine ufficiali Facebook e Google+.
Oltre ai contenuti esclusivi - tra cui foto, video ed interviste con il Team - ci saranno anche dei contenuti aggiuntivi a disposizione di tutti coloro che si sintonizzeranno il giorno della presentazione.
Inoltre, gallerie di immagini e specifiche tecniche della vettura saranno disponibili sul sito web non appena la vettura sarà stata svelata - quindi assicuratevi di essere pronti a sintonizzarvi a partire dalle ore 10:30 (11:30 ora italiana).
YouTube - Iscriviti al nostro canale YouTube per essere uno dei primi testimoni della presentazione della MP4-28.
Google+ - Seguici qui per vedere la presentazione della monoposto e per altri contenuti esclusivi.
Facebook - Seguici per guardare la presentazione della monoposto attraverso la nostra nuova applicazione Facebook con le immagini di tutta la giornata in esclusiva.
Twitter - Seguici per tutti gli aggiornamenti minuto per minuto, diffusi dal nostro @TheFifthDriver.
fonte: mclaren.com
non vedo una pippa.....e ti pareva...
Neanche io... sito troppo pieno.
dai su...via sto velo....checo su instagram ha gia messo una foto.... :-supp
L'hanno già svelata? Io vedo che sta parlando Michael.
OMMIODDIO BRUCE MCLAREN IN PERSONA !!!!! FANTASTICO.....
Prima impressione: sotto il velo mi pare di vedere un musetto bello alto, con punta arrotondata tipo papera, ma ripeto, solo impressioni.
Citazione di: Mika85 il 31 Gennaio 2013, 12:03:18
Molto bella come introduzione. Complimenti :-appl
LE MACCHINE CHE HANNO FATTO LA STORIA!!! STO MORENDOOOOOOO
raga sto male. ho le vertigini
ahhhhhhhhhhhhhhh mio dio mio dio mio dioooooooo
LEWIS....GUARDA CHE TI SEI PERSO.
